Which box to put a 12'' woofer and other important ??
duane26
duane26 Posts: 15
edited January 2005 in Car Subwoofer Talk
I was looking at the Q-Logic QLH-.8512se for the MM2124, any thoughts? Absolutly no way I am building one. Is this a good MDF box for $65?
http://www.cardomain.com/item/QLCQLH8512SE?ref=prgr
Is .85 cu. ft. close enough to polk's recomendation .88?
How would I go about instaling a box in the trunk of my 00' civic si coupe? Is there special brackets or something to keep it in place? I love taking quick turns.
Also, I was going to go with a 4 gauge streetwires kit for my amplifier, MTX Thunder 684, is this a good choice or should I go with Fosgate, lightning, phoenix gold, stinger?
Thank-You for your time!
Post edited by duane26 on
  • exalted512
    exalted512 Posts: 10,735
    edited January 2005
    the box should stay in place, if not you can get some heavy duty velcro and it wont budge. for amp kits id recommend knukonceptz.com
    great stuff and an even better price
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2005
    Streetwires, Stinger, Knuconceptz, Tsunami are all very good wire. Youll do fine going with any of them. Just dont use Monster Cable.
    As long as that !-Logic box is ALL MDF and no plastic it will be fine.
  • Systems
    Systems Posts: 14,873
    edited January 2005
    ok. look this answer, ===> www.s_car_mix_i.uk
    Testing
    Testing
    Testing
  • MacLeod
    edited January 2005
    Looks like we've got a bot on here.
    This is the 4th stupid link on here. Somebody need to zap his IP address.
