Advice on Rear Center Speaker
My system is four RTi6's for the fronts and the surrounds, a CSi3 for the front center and a PSW404 subwoofer.
I would like to add a speaker for the rear center.
What would be a good choice?
I would like to use another CSi3 for asthetic reasons, would this do well?
Sincerely,
Diogenes
Sincerely,
Diogenes
Post edited by Diogenes on
Csi3 would be the perfect choice. Alternatively, you can get a Csi5 for the center channel and put your existing Csi3 in the rear.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Yeah, the CSi3 would be a good choice for the rear.
What amplification are you using to power this system?
Also, what part of Oklahoma are you from?
I'm originally from OK-.OKIEpolkie.Tschüss
Zach -
My speakers are powered by an Onkyo TX-SR601.
I live in Oklahoma City...I figured the tie in with your name....pretty cute...:)
Nice idea about getting the CXi5.... -
I would second Early B. with getting a CSi5 for the Front and mofing the CSi3 back, I use a CSi5 and RTi6 for my frontstage and it sounds great.
