r monitor 60s compatible with 'terminated' biwire cables?
baboon
baboon Posts: 60
i was curious if they are compatible with the MIT terminator Bi-wire cables. Or would I be better off buying ones with out the big block?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14966&item=5742096868&rd=1
thanks!!
Post edited by baboon on
  • Whadyasay
    Whadyasay Posts: 300
    edited January 2005
    It depends on how large the spade openings are and how large the binding posts on your speakers are. You could always just insert one prong of the spades through the hole in your speaker's posts, but that's usually not ideal. Try contacing the seller and finding out the spade opening size, then check the diameter of your speakers binding posts. Bananna plugs and recepticles are all pretty much one standard size.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
