Need SubW
BossHog
BossHog Posts: 16
edited January 2005 in Speakers
I'm looking to add a sub w to my new system.
Currently using a HarmanKardon AVR130 / Polk R30's for the front's and Polk R15's for the surrounds.
Polk recommends the PSW 202 sub for my set-up but this model isn't available in my area.
I was considering the PSW 10, is this a good match for my system? Is it compatible??
New to this stuff but I want to keep my system compatible.
Thanks!
Post edited by BossHog on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    The PSW10 should be a nice match for your system. From what I remember someone saying, they are the same woofer and amplifier. They just have a different cabinet.
    Tschüss
    Zach
  • Toxis
    Toxis Posts: 5,116
    edited January 2005
    possibly the same amp but if you look at the driver itself, it looks a lot beefier on the PSW10. The 202 was a joke IMO, but then again, the PSW10 and 12 have some of the worst port noise I've ever heard on a home sub... or ever.
  • Fulmer
    Fulmer Posts: 26
    edited January 2005
    Here's two very good options as Polk is not particularly well regarded for thier subs. The first is the Dayton 10" sub from partsexpress.com. It goes for about $99 online. It is said to outperform almost anything costing about 3x its price. Go to hometheaterforum.com or avsforum.com and do a search in their speaker sections for it. You'll see a lot of praise for this budget subwoofer that many call the "tiny mighty". And, the second recommendation under $200 would be the Atlantic Technology T70.1 PBM. It's a pretty nice sealed 10" design which sounds as good for music as it does for movies. Both subs play down to 25Hz which is quite a feat at these prices. Good luck in your search.
    Fulmer
    TV: Hitachi 51F500
    Receiver: Yamaha HTR-5240
    Mains: R50
    Center: CS245i
    Surrounds: RT25i
    Sub: Atlantic Technology T70
  • kdking78
    kdking78 Posts: 1
    edited January 2005
    The psw12 is a better subwoofer. it is lfe compatable, it throws out deep bass, and it outperforms some subwoofers that are rated at a higher rms. I know because I just bought one.
  • BossHog
    BossHog Posts: 16
    edited January 2005
    Fulmer, I'll have to check around my area for those brands you suggested....Canada.
    I found a good deal on a Polk PSW 303. How would this unit match up with R30 front/ R15 rears???
  • Willow
    Willow Posts: 11,056
    edited January 2005
    check out this site
    http://www.homedigitalav.com/index.html
    they sell HSU in canada...
  • Willow
    edited January 2005
    what should I be hearing? i have the 202
  • kingtut
    kingtut Posts: 813
    edited January 2005
    I had the Atlantic Technology T70PBM. It goes down to 25 hz and was very good for musics and movies, if you have a smaller room. Being that it's a sealed design, it's not as efficient as the ported subs for larger rooms.
  • okiepolkie
    edited January 2005
    The 303 would be okay if is a really good deal. There are better subs out there, but good deals are often hard to pass up.
    Tschüss
    Zach
  • Teejai
    Teejai Posts: 43
    edited January 2005
    I have the 303, cost me all of $100 when I bought my speakers last year. They had the deal of a free sub with purchase of $400 or $500 of Polk speakers, so I upgraded from the free sub to the 303. It only has an 8" driver but it does ok for me.
    Yamaha RX-V661
    RTi6
    CSi5
    FXi3
    PSW303
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2005
    If you're in Canada is it still realistic for you to order from Partexpress.com? If so, definitely check out the Dayton. I picked up a while back for a second HT setup and it works and sounds beautiful. There is a bit of assembly (at least there was with mine) but nothing difficult.
  • BossHog
    BossHog Posts: 16
    edited January 2005
    Well, living in Canada does have it's limitations when ordering from the US. Not that it's impossible but rather the cost involved is outragous with regards to frieght, duty rates, custom fee's and not to mention the dollar exchange rate....in the end a good deal may amount to a loss. And don't get me going with UPS and Fedex cost.
    However, I did come across a PSW303 for $249 US. Think I may go for the 303
