receiver vs. external amp?
re510
re510 Posts: 29
edited January 2005 in Electronics
I have a yamaha receiver that is 105w x 6. I was thinking of getting a multichannel amp, there is a carver av405-5 that is 100W Left/Right, 110W Center, 50W L/R Rear 5 channels total the guy is asking $300 is it worth it & will i be able to tell $300 worth of difference?
System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Post edited by re510 on
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited January 2005
    My parents have that reciever, but I never did a head to head comp so take that for what it is worth:
    The didicated amp will most likely sound much clearer then the reciever from my experience. Using a Kenwood VR-7070 as the pre and RT800's as the speakers, there was a substantial difference between my reciever doing the amplifying and my Carver A500X. So much so that I know that at moderate or higher volumes I could pick the difference 100% of the time.
    In your case, you have (what I believe to be) better reciver than I had, but a lesser amp so the change may not be as large for you.
    Is it worth $300? Well, only you can make that determination.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Early B.
    Early B. Posts: 7,900
    edited January 2005
    Yeah, get the Carver. It'll be money well spent.
    "God grooves with tubes."
  • danger boy
    danger boy Posts: 15,722
    edited January 2005
    just make sure your Yammie has preouts. i remember someone (who's name escapes me (sid) who's receiver did not have pre outs. there is no way to hook up a amp to a receiver without pre amps. FYI
    PolkFest 2012, who's going>?
  • sowen010599
    sowen010599 Posts: 343
    edited January 2005
    There is a way to do it, but it's a huge hassle. I helped a friend get one going with an HK AVR 110, it has no pre-outs. After a trip to the Rat Shack, I got it to work.
    Go BIG or go home!
