Ive decided on parasound 1500a
minime
minime Posts: 42
edited January 2005 in Speakers
What type cables should i use for the amp? Whats the best speaker wire hookup for my setup. and any other imput i could use.
Denon 3802
RTI 12 fronts
CSI5 center
FXI5 rears
Samsung 841 dvd
Sony CDP C-325 dvd player
sony Cassette player TC-RX79ES
Post edited by minime on
  • steveinaz
    steveinaz Posts: 19,538
    edited January 2005
    Audioquest Bedrock (See Audio Advisor) is up to 72% off. Outstanding speaker cable.
    Audioquest Copperhead, Sidewinder, or Diamondback IC's.
    Enjoy! I love my HCA-1500A. Give it plenty of room for cooling, especially the top; at least 8" clearance if its in an enclosed rack. You can get away with less room in an open rack.
  • Early B.
    Early B. Posts: 7,900
    edited January 2005
    Another vote for Audioquest.
    "God grooves with tubes."
  • minime
    minime Posts: 42
    edited January 2005
    and with my set-up which amp should i use for the highs and which for the lows? I see alot of info on bi wiring out there and would like some imput on what you guys think. will good wire do the job just as well as buying these hi dollar cables? How in the hell could frick-en speaker cable cost that much (theres a conspiracy going on):confused:
  • dorokusai
    dorokusai Posts: 25,577
    edited January 2005
    Excellent choice in amplification, it's a real solid piece.
