Got Tubes???
Early B.
Early B. Posts: 7,900
edited January 2005 in 2 Channel Audio
I just received my Jolida integrated amp, and after one minute of playing, one of the power tubes died (Svet 6550). It may be due to a bad tube or a biasing problem, but I don't want to buy new tubes until I know for certain why the tube blew out in the first place.
Just wondering if any of you guys have any used 6550's laying around that you can relinquish to a fellow Polk brethren. If so, please PM me.
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • organ
    organ Posts: 4,969
    edited January 2005
    Sorry to hear about that. Did you buy used or new? If new, the store should have a warranty on the tubes as well.
    Depending on how your amp was designed to be biased, you can't just pop another 6550 in there. You'll need a matched quad. Did you look underneath to see if there's any damage on the amp? It's probably just a bad tube. If you find out it's the tube, order a matched quad and make them send it out express. That sucks, the amp didn't even get to warm up yet.
    Maurice
  • HBombToo
    HBombToo Posts: 5,256
    edited January 2005
    Thanks.
    I agree.
    h
    ***WAREMTAE***
  • Early B.
    edited January 2005
    According to the manual, they don't need to be matched. However, I'll eventually buy a new matched set.
    No damage that I can tell.
    I bought it used. I've spoken to the previous owner already, but I want to see if it's just a bad tube before I talk to him again.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2005
    I'm fairly certain I have a Sovtek 6550 single around here.
    Let me look.
    Cheers,
    Russ
  • Early B.
    edited January 2005
    A big shout out goes to Madmax for hooking me up with the spare tubes I need. I should be back in business by Friday.
