CS series vs. CSi series
I've been thinking of getting a new center and moving the existing one to the back. Would i be better off with a cs400i or buying a new csi3 or 5.
System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Post edited by re510 on
I believe the CS400i is voice matched with your fronts and if so would be the best choice. I'm not sure how easy it would be to find though, probably have to look on Ebay or Audiogon.
I know a CC around me has a CS400i, maybe it would be worth your while to check a CC in your area?
can you tell me what city that CC is in maybee i can call and purchase over th phone?System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
