RTi8's with RM6600 system
My uncle has an RM6600 system we installed about a year ago. He's looking to upgrade his front speakers. Would the RTi8's match well with the center and rear speaker of the RM6600?
Onkyo TX-NR901 Receiver
Sony DVP-NS975V DVD - Player
Microsoft X-Box with HD Pack
Samsung SIRTS360 HD Directv Decoder
Panasonic HDTV PT-AE700U Home Theater Projector
Da-Lite Cinema Contour HC 106" Screen
Harmony 688 Remote Control
JVC HM-DH4000U D-VHS Digital Video Recorder
Monster Reference PowerCenter HTS 5000 MKII with Clean Power Stage 4 v.2.0
Polk RTi10 Fronts
Polk CSi5 Center
Polk FXi5 Surround
Polk RTi6 Rears
Polk PSW505 Sub
Polk RTi10 Fronts
Polk CSi5 Center
Polk FXi5 Surround
Polk RTi6 Rears
Polk PSW505 Sub
Post edited by yobear on
No.
Fronts and center, absolutely not.
Fronts and rears, it won't matter so much.
Plan on purchasing a matching center, ie. the CSi5.Go BIG or go home! -
Then what would be a good match?Onkyo TX-NR901 Receiver
Polk RTi10 Fronts
Polk CSi5 Center
Polk FXi5 Surround
Polk RTi6 Rears
Polk PSW505 Sub -
I think the point is that you will have to replace the front stage when you do the upgrade.
For Home Theater think of the fronts and center as a set. The rears are less important. (If you get into Concert DVD's or SACD, that will change)
When you upgrade (whatever you upgrade to) you will have to change the center channel as well. As a matter of fact, I would say you will get more improvement from the center channel upgrade than the front left and right. (for home theater anyway)
Just my opinion of course...
