Received the "T" amp yesterday!!!
madmax
madmax Posts: 12,434
edited March 2005 in Electronics
Someone posted this ad and I bought one.
http://www.thinkgeek.com/electronics/audio/6cd8/
It is a Sonic Impact 15 watt Class T battery powered amplifier for $23.
I received it yesterday, took it home, hooked it up and gave it a whirl.
I started about 5:00. I disconnected my Jolida 502 amp and connected the T amp. The system is:
Theta Data Basic II CD transport
AudioNote Tube DAC
Audible Illusions Modulus 3A tube preamp
Sonic Impact T amp
SDA-SRS speakers
MIT interconnects/AudioQuest speaker cables
Knowing this amp will only output 5 watts or so per channel I started at very low volume. The first song I played was from Santana Supernatural. Well, I thought I had it turned down but the preamp was set fairly high. The first bass drum intro on the CD blasted out. Oh ****, I must have disconnected the wrong amp or something... As I'm standing there scratching my head the sound intensity increases quite a bit (recorded that way on the CD) and distortion sets in. OK, so yes, it IS the T amp playing.
After adjusting the sound to a reasonable level I sat back and listened. Supernatural has a very pronounced bass level. The T amp was reproducing it clearly with force. After a few songs I tried increasing the sound level a bit and distortion set in so I backed off.
Next I tried something lighter on bass. I was able to get the volume up quite a bit without distortion. Actually it was plenty loud and I backed off a little.
Now it is about 9:00 and I've gone into a new mode of listening. I'm wanting it louder but it keeps distorting. I paid a lot of attention to how it distorts. It doesn't do it nicely like tubes, but not like SS either. It outputs a static type sound when it distorts. It is as if you hear no distortion to some point and full distortion after that point. I can see validity in a statement they make in the manual. "Audiophile sound".
At about 10:00 I tried some LP's. They react much like they do with the tubes. Very smooth but not real dynamic. (function of my cartridge and preamp).
Lets just say this, at 1:00 AM I went to bed but would have been happy to listen even longer.
Overall I am very impressed with this amplifier. I am ordering another one today and will try a bi-amp system next. There is probably a lot of room for modifications with this unit. I read elsewhere that Vinney Rossi (the guy who started a lot of the Toshiba mods) has already started modifying them. He is a very good judge of what has potential and I'll look forward to seeing what he does. Until then I'll follow the traditional route of increasing capacitance, shorter signal paths, etc. I think this amp has very good promise.
Just imagine if I had efficient speakers! I'll bet for around $600 you could have a very nice entry level audiophile system. A $50 3960 Toshiba CD player with mods, a $23 T amp with mods and a pair of high efficiency full range driver speakers like the Fostex.
madmax
Edit: Sound levels. With my RS meter, at high volume, I was staying at about 90db 1 meter away from the speaker. At my listening position it was about 80db average. Not enough for loud listening but plenty for low level listening. I could approach my normal average listening but couldn't quite get there.
Vinyl, the final frontier...
Post edited by madmax on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited December 2004
    I've got a pair of those amps laying around, time to hook em up!
    Cheers,
    Russ
  • gidrah
    gidrah Posts: 3,049
    I've had one for a little while. I haven't hooked it up yet though. Even with my Altecs I'm thinking I'm gonna want a little more power. I had the ST-70 cranked today and wanted a little more.
    Make it Funky! :)
  • phoneisbusy
    phoneisbusy Posts: 867
    A lot of people in this forum have been having fun with it. Some of the tweaks worth far more then the amp itself! :eek:
    http://www.diyaudio.com/forums/showthread.php?s=&threadid=41846
    regards
    Dave
    Happy New Years to everyone while I'm at it.
    Time is the best teacher. Unfortunately it kills all its students.
  • madmax
    Whew, that took some time to read... Seems they are not common ground. They did work well with the SDA-SRS though. Hmmm...
    madmax
    F1nut Posts: 51,783
    MM, when you get this amp settled in, I want to hear it.
  • Mjr7531
    Mjr7531 Posts: 856
    edited January 2005
    I fot the amp for my sis for her b-day, and while she is in mexico, I'm breaking it in for her :) My favorite feature was running the thing off of batteries. This unit really does sound great.
  • madmax
    edited January 2005
    No problem. It will take you a little while to warm up to 5 watts. After listening to your system mine sounded pretty lame. I finally figured out I was trying to listen too loud. Seems like that would be an obvious thing but it took a long time to figure it out. All of a sudden it sounded like the soundstage became half the size and the toneality was different, wrong. After cranking the volume back a little things came back. Seems I was doing this without even realizing. :)
    madmax
    F1nut Posts: 51,783
    edited January 2005
    Glad to hear that you're enjoying the music again.
  • madmax
    edited January 2005
    I've got another T-amp on order so I can bi-amp the SDA-SRS. That will be a gut wrenching total of 20 watts going to those beasts!
    madmax
  • HBombToo
    HBombToo Posts: 5,256
    edited January 2005
    madmax
    since your taking this too a higher level lets start swapping batteries for good marine batteries:D
    ***WAREMTAE***
  • madmax
    edited January 2005
    Great Idea!
    madmax
  • HBombToo
    edited January 2005
    Great Idea!
    madmax
    every now and then a blind squirrel finds a NUT:D
    1/4twin
    ***WAREMTAE***
  • Danny Tse
    Danny Tse Posts: 5,206
    edited January 2005
    Now go "dress up" your T-amp with the below....
    http://mywebpages.comcast.net/ampbox/page2.html
  • madmax
    edited January 2005
    That is an awesome box!
    madmax
  • madmax
    edited January 2005
    I know that seems like a lot to pay for a box to put a $27 amplifier in but I'm thinking about it.
    madmax
  • RuSsMaN
    edited January 2005
    I'm ordering that box, that's awesome.
    Cheers,
    Russ
  • Danny Tse
    edited January 2005
    madmax
    Come on, don't deny yourself :D
    We need pics when you are done.
    BTW, I have no connection to the manufacturer of that awesome-looking metal case for the T-amp. I don't even have a T-amp myself.
  • polksda
    polksda Posts: 716
    edited January 2005
    This is another cool discussion of a modded Sonic-T. More expensive for the full blown version (we're into real amp prices here), but it's cool to read the extent to which this chip-based amp technology can be taken in the right hands (not me, I'm all thumbs when it comes to DIY).
    http://www.audiocircle.com/circles/viewtopic.php?t=14587&highlight=sonic+impact
    Here is some more fodder for the digital amp mavens, and the Tripath subject in general.
    Last week Vinnie Rossi sent me a prototype battery powered Tripath amp based on the chip found in the PowerWave and Sonic Impact, the 2024, I believe it is. He has worked hard on optimizing the signal path, using audiophile grade electrical components, employing a few discoveries made along the way. The unit came in a natty black powder-coated aluminum case, with machined aluminum volume control and spiffy blue LED 'on' light on the front. I should mention that my absolute first impression of the amp was its fit n finish. Vinnie did a really nice job on this Tiny Terror.
    Initial Sonic Impressions
    Zero Noise. None, nada. We're ready to spin and we're off the National Electrical Grid here and with a battery powered Scott Nixon DACkit, and this concept makes me happy. icon_mrgreen.gif The need for complex power conditioning is naught.... Music arises from a completely black background. This only serves to enhance the now well known ability of Tripath amps to "unbundle" individual instruments from even dense mixes.
    Warm midrange typical of Tripath sonic signature, as is bass control even at very low volume. Strident, etched highs more often noticeable with string and piano sounds, which contain complex harmonics in the upper-register. This is due almost entirely to the fresh, as yet un-worked chip, and it is exactly what I expected. It has been well established over the last couple years that one should not really judge the Tripath sonic before the first THREE months, left on full time, so burn in will likely take longer here.
    Out of the box, the VinnieR amp completely eclipses the ability of the batter power Sonic Impact; I really didn't expect it, but this is an entirely different beast, with tons more speaker control, and just alot of sound coming from this little box.
    Nothing Accesses Current Like A Bunny:
    The optimized amp with battery power makes an already fast amp even faster, and was commented on by the kids as well. Attack transients were often startling. --Absolutely superb speaker control. I played it loudly for six hours on Saturday, and it recharged in under 20 minutes. Such is the nature of highly efficient digital amps. This one keeps going and going and...
    Flea Amp?
    Depends on your speakers. Using drivers with real world sensitivity, over 90db in my book, this approach might be all the amp some of us would ever need. Using outstanding drivers like the Fostex FE207E, (96db) and the Radian coaxial 502/B (97db) the bat-T-ery amp has more than enough juice to drive even the most hardened headbanger howling from the room. I know, because I did just that to a real headbanger on Saturday. The crossover-less Fostex, though far from broken in its supposed mandatory minimum 100 hours, sounded best, exhibiting better synergy to my ears, than even the Radians. So far sooo good.
    F1nut Posts: 51,783
    edited January 2005
    3 month burn in time.........Give me a fricken' break!
  • bknauss
    bknauss Posts: 1,441
    edited January 2005
    People are silly when it comes to chip amps. I can't believe there's a section dedicated to chip amps on diyaudio.com.
    If you want something made by Tripath, I suggest getting it soon. They're in a heap of legal troubles, so I don't see many companies who are more than willing to jump on board with these guys... although Panasonic is doing car head units with their chips.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • polksda
    polksda Posts: 716
    edited January 2005
    Why are chip amps silly? Is there something inherently inferior about the technology?
  • madmax
    edited January 2005
    I gutted out the T-amp on Friday. Very nice little board. I can't wait to add caps, change the wiring around, add a nice pot, change all the connectors, add an SLA battery, etc. I ordered two more so after I do all this work I will still have two that function. :D
    madmax
  • Danny Tse
    edited January 2005
    madmax,
    did you order the metal case for the T-amp?
  • madmax
    edited January 2005
    No, not yet. I just ordered some efficient speakers (not to mention an RC race car) and decided to put off the case for a bit. I emailed the guy and he offered the parts to go with the case. It was something like $160 or so with all parts (except board), polished and pre-drilled. Seems like a real nice fellow too. I'll probably order one next month. I have not decided whether I want a volume control or not either. I read that some decent pots may cause a loss of sound quality over the cheapy one in the amp. This makes me want to try a nice resistor first before deciding on how many holes to put in the case. I may cheap out and drill my own holes and polish it myself but I keep going back and forth. His prices seem very reasonable for these operations.
    madmax
  • bknauss
    edited January 2005
    There is a limited amount of improvements you can do with chip amps, so they're not inferior, but discrete amps just have the ability to be much better. I call it silly because some people think they're the end-all of amps. Yea, they're cheap, easy to make, and from what I've heard they sound decent, but I'd put a big ol' discrete mamma-jamma up to any of them any day.
    Brian Knauss
  • Danny Tse
    edited January 2005
    $5,000 Samsung THX-Ultra2 A/V receiver with digital amps....
    250 watts/channel X 7 (full bandwidth)
    http://www.audioholics.com/ces/CESprocessors/SamsungAVR3000THXreceiver.php
  • madmax
    edited January 2005
    On the chip amp side I have to say I like the fact that they do not have all the variables of discrete parts. No antennas between every component, no solder connections (within the chip), low inductance and capacitance between stages etc. They have the ability to be consistantly better than their discrete counterparts for pennies on the dollar.
    madmax
  • Early B.
    Early B. Posts: 7,900
    edited January 2005
    Anyone order that box for the Sonic Impact yet?
    "God grooves with tubes."
  • madmax
    edited January 2005
    I received mine on Monday. It was exactly as described. I ordered mine with no extras. It comes with the pilot holes but I have to drill them, polish the case and install my own connectors, etc. Art will build it up to whatever level you wish. I am very happy with the product. Here at work I tried to find alternate enclosures. The closest thing I found was cheaply made, didn't look as cool and the cost was about $80. Art has a great price in my opinion.
    madmax
  • Danny Tse
    edited March 2005
