7.2 Speaker Set Up
chluffey
chluffey Posts: 28
edited January 2005 in Music & Movies
I am setting up my stereo in a new house and am finally able to use the free PSWW202 that came with my 150s. The question is (and I know everyone will say it depends on my room) but for GENERAL - INITIAL set up, is it better to have 2 subs along the same wall or in opposite corners of the room ?
Onkyo TX-SR800 set up for 7.2
RTi150s Mains
RM7600 Surrounds & Center
PSW650 Sub & PSW202 Sub
Denon DVM1805 DVD
Toshiba 32 in. HDTV
Post edited by chluffey on
  • sowen010599
    sowen010599 Posts: 343
    edited December 2004
    Stacked, one on top of the other, in the same corner. Or, 4 subs in the center of all four walls.
    Go BIG or go home!
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I second Sowen, my stacked 450's sound much better this way than when I had them one in front corner one in back.
    RT1
    F1nut Posts: 50,656
    I think one in each corner with one in the middle of the room would work best. When the ceiling comes crashing down, don't blame me.
  • Early B.
    Early B. Posts: 7,900
    Here's another suggestion -- Since you have 150's up front, set them to LARGE, sell the two subs you have, get a monsterous SVS or Hsu and set it close to your seating position. Bass all over the place, dammit.
    "God grooves with tubes."
  • Airplay355
    Airplay355 Posts: 4,298
    stick a sub somewhere then walk around till u hear where the bass is weakest....put the other sub there....
    im not sure if that works, but someone told me to try it...since i dont have 2 subs, u try it :p
  • PolkThug
    PolkThug Posts: 7,532
    I've done tons of moving subs around running freq sweeps, and they always sound best stacked in the corner. Putting them in opposite corners has always caused dips/nulls at certain frequencies. I've done this with Polks and SVS.
    *Of course, everyone's room may be different. My room is a closed rectangle.
    Regards,
    PolkThug
  • chluffey
    chluffey Posts: 28
    edited January 2005
    Thanks fellas, I've actually never heard of stacking subs, but I'm going to give it a try this week. I was afraid of putting them in two corners and getting dead spots like Polkthug said. Thanks again for the help.
    RTi150s Mains
    Denon DVM1805 DVD
    Toshiba 32 in. HDTV
  • Early B.
    edited January 2005
    Your system will never sound good with those Monster connections you're using.:p
  • chluffey
    chluffey Posts: 28
    edited January 2005
    Yeah, I've heard that from a bunch of cranky pants people before, but I just can't bring myself to spend hundreds and hundreds of dollars on interconnects and speaker wire while I have a mortgage and a car payment to pay, dig ?
    RTi150s Mains
    Denon DVM1805 DVD
    Toshiba 32 in. HDTV
  • sowen010599
    edited January 2005
    There is nothing really "wrong" with Monster Cable cables, it's just that there is something VERY WRONG with the way they do business. There are better products out there for the same price, or even less, and many more companies much more deserving of your hard earned dollars.
    Go BIG or go home!
  • chluffey
    chluffey Posts: 28
    edited January 2005
    What would you reccomend in the same ballpark price range ? I can't afford MIT's and the like from what I've seen and read pricewise.
    RTi150s Mains
    Denon DVM1805 DVD
    Toshiba 32 in. HDTV
  • McLoki
    McLoki Posts: 5,231
    edited January 2005
    similar price and higher quality would be signal cable or blue jeans cable.
    michael
  • chluffey
    chluffey Posts: 28
    edited January 2005
    Thanks Michael, I'll check those out.
    Chuck
    RTi150s Mains
    Denon DVM1805 DVD
    Toshiba 32 in. HDTV
  • chluffey
    chluffey Posts: 28
    edited January 2005
    While we're at it here, can anyone recommend an affordable, but decent 250 to 300w stereo amp ? I'd like to power up my 150's with something a little more pwerful than my Onkyo's 100wpc but don't have an arm and a leg to spend on it at the moment.
    RTi150s Mains
    Denon DVM1805 DVD
    Toshiba 32 in. HDTV
