Where do i find a new grill
Striker1817
As everyone knows right now i own a pair of klipsch KG 4.5. Being an old model it has been through a lot and i do need a new grill for them. Where do i find an old grill to fit a big speaker. Should i contact the company or should i try to replace the cloth....which would be easy to do and not a killer on my wallet.
Chris(16 year old speaker freak)
Post edited by RyanC_Masimo on
If you still have the grill frame, get it reclothed or do it yourself. It'll only cost you a couple bucks. I'm haveing my old JBL frames reclothed and its gonna cost me like 9 bucks for both of them.
Where can you go to get them reclothed?
Well, I just took mine to a local speaker repair shop. If you don't have one near you, you can always just order the cloth and do it yourself. It's very innexpensive.
Thanx a lot man that helps me out a lot. I have a place close to me that referbishes speakers so they will probibly do this for me. Thank you so much.
-Chris(16 year old speaker freak) -
kn505,
If you cannot find the correct grill you shuldbe able to use a breathable black polyster cloth. Places like Joan Fabric should have this material.
J
Polk Audio
Customer Service
