The Hosers do it again - PSB Century 800i
RuSsMaN
RuSsMaN Posts: 17,986
edited December 2004 in Speakers
Picked these up this week, PSB Century 800i's from fellow Polkie 'mesquitehead'.
From the PSB website:
->With two 8-inch woofers that employ new voice coil materials and higher-temperature adhesives for increased power handling, the 800i supplies the impressive bottom end at high listening levels you might expect, with a low-frequency cut-off point of 30 Hz and the ability to stir a lot of air in motion at all-out symphonic or rock levels in big listening rooms. It uses the same new 1-inch textile dome tweeter as the 600i , and has the same well-dispersed top-end response. You would be hard-pressed to make this speaker sound at all stressed.<-
Pretty good sounding speaker so far, lots of good, deep bass - but still maintains an outstanding transition from mid to tweeter. Front ported, bi wire/amp capable. The inverted surrounds on the woofs are a nice touch, almost 'throwback' if you will.
Cheers,
Russ
Post edited by RuSsMaN on
    VR3 Posts: 29,401
    More speakers?
    Hmm, I guess you gotta replace the RT8 with something! hehe! Those look great, never owned an OEM speaker with 8" woofers, would be nice!
    Lookin good man...
  • mesquitehead
    mesquitehead Posts: 312
    Glad you like them...it was great to meet you and hang out a bit, hope you are enjoying the kgsr discs as well. Hopefully next trip I will have the "living Room " built. I scored me a set of rta11t's last night to add to the mess. Oh and a big thanks for the grillz...they will look nice in the "living room" and add to the waf situation. Happy new year and Hook'em Horns !!
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
