Bass Level?
vibes
vibes Posts: 3
edited February 2002 in Technical/Setup
I have a PSW350 10" sub connected through the main outputs of my Yamaha receiver.
With it hooked up through the main outputs any adjustment to the bass knob on my receiver is going to be passed through to the sub...
I have the crossover set to around 80Hz but how do I set the gain...
Do I increase the bass on the receiver and use less gain on the sub or leave the bass flat on the receiver and increase the gain on the sub?
Please advise, thanks!
Post edited by vibes on
  • goingganzo
    goingganzo Posts: 2,793
    if you want more bass increase the gain on the sum and dont mess with the bass on the recever unless you want the bass to be boomy eq are good but you nee alot of equipment to get them right
