Connecting speaker wires
Early B.
Early B. Posts: 7,900
I have two lengths of speaker wire that I would like connect to each other. I don't want to solder them (don't have the equipment), nor do I want to twist them together and bind it with electrical tape. Is there a better way to do this?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • Whadyasay
    Whadyasay Posts: 300
    edited December 2004
    Other than shrink tubing (which is probably ideal), there aren't many other alternatives.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • TheReaper
    TheReaper Posts: 636
    Twist them together and put a "wire nut" on.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • Early B.
    Wire nut. OK. Thanks. Didn't think of that one.
  • dorokusai
    dorokusai Posts: 25,576
    Put your head in between the ends, even cheaper.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Solder would be best and I know you don't have a solder iron.
    So doesn't "Rat Shack" sell some "Solder Tape" that can be wrapped and melted with a match? At least I think I seen something like that before.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    Found what I was talking about, these soldering tape idea.
    So with these tape thing, and some Heat shrink tubing you're all set.
    Here's the link...
    http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F009%5F007%5F001&product%5Fid=64%2D010
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    Remind me not to ask any of you guys to fix anything for me.
  • disneyjoe7
    I didn't say I ever used that stuff, but I do think it's a little better then wire nuts. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
