Ps2 as dvd player
Willow
My bro is getting a htib for xmas...he has a ps2 is ok as a dvd player is it hard to hook up what do I need to buy him in order to hook it up ?
I bought him a toslink....what about video ?
thanks
thanks
Post edited by Willow on
I hooked a friend's PS2 to my rig, all you need is that toslink fiber cable you got him and their composite and Audio RCA L/R converter thingie that comes with it to plug in the video. Just leave out the RCA audio, the optical will still work.
Thanks I don't have one so I had no clue what vidoe cables were used.
depends on his TV but you can buy S-video and Component video cables for the PS2. Otherwise, you just use the Composite video cable that came with it and it's all good. Just use Toslink for the digital audio and be gravy.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Does he need a special cable for svid? I have 3 lying around he could have ...
PS2 works fine as a dvd player. Just make sure you use the optical out. The d/a audio converters in the PS2 are really bad.
Originally posted by Willow
Does he need a special cable for svid? I have 3 lying around he could have ...Never kick a fresh **** on a hot day.
Originally posted by Toxis
there's a special adapter that uses S-video out for PS2. You'd need to pick one up.
Target has some fairly nice priced PS2 cables with s-video... I think it was around $10. Another option would be ebay.Brian Knauss
ex-Electrical Engineer for Polk
