RT5's
Systems
Systems Posts: 14,873
edited December 2004 in Car Audio & Electronics
Please forgive the ignorane in this question but here goes. I have 3 sets of RT5 speakers and upon setting them up in my new home one of the speakers midrange would not play. I switched speakers from other locations and all others played fine. I was told that it was the voicecoil in the mid and I should replace the mid. Is this the case??? The tweeter still plays fine but no mid. All the wiring is okay. What to do???
Testing
Testing
Testing
  • exalted512
    exalted512 Posts: 10,735
    if you just moved them it should not be a blown voice coil. if you sure its not the wiring(have you made sure its not the channel on your receiver thats bad?) i would try checking the little wires that go from the terminal to the cone? that would make more sense than a bad voice coil. also, this is the car audio forum, you might have better troubleshooting luck if you go to the home theater side.
    -Cody
    VR3 Posts: 28,776
    I would take out the terminal on the back, check the crossover to make sure all is well...
    Maybe even swap mids between your speakers...
    Does your speaker make a crackling noise? If not, it sounds like a crossover... If you blew the woofer, you'd know it... It would sound you hadnt been to the bathroom in a REAL long time..
  • MacLeod
    MacLeod Posts: 14,358
    Its cool to have our own residential HT expert over on this side!
    Good on ya Sid! ;)
    VR3 Posts: 28,776
    Good on ya Sid! ;)
    waaaaaaaaaaaaaaaaaaaaa
    Thanks... (if only he knew!) ;) waaaaa
    The residential HT expert is jamming to 5 dollar computer speakers... I think its the whole random songs with 133 hours of it thats intriguing, the sound sucks..
  • MacLeod
    Well at least you finally got some comp speakers! ;)
    VR3 Posts: 28,776
    So true!!!
    A forum member hear gave me a new SC and a cable to connect my integrated to it... nice nice nice
