SW10 Question?
raidical
raidical Posts: 11
I have owned a Polk SW10 for about two months now and have noticed alot of people posting threads on it not being magnetically shielded. I have a Toshiba 50" front projection TV and have my SubWoofer sitting right next to it. I haven't noticed any problems at all with it being Magnetically not shielded but should i have it moved or does it make a difference using a projection TV. Thans for any info.
Post edited by raidical on
  • sjdgpt
    sjdgpt Posts: 2
    edited December 2004
    If you are having a problem with the unshielded sub, it would be most likely the color of the TV being pulled out of the TV.
    The only time I have seen the effect, it looked as if the green was being sucked from the scene and was puddling in a rainbow effect on the edge of the screen. If that makes sense.
    Distance is your friend. If you don't notice a problem, give yourself another inch or two, and you should be safe.
    Do I really look like I know what I am doing?
    Say Hi to you wife for me.
    I see said the blind man as the deaf mute hammered the nail into his thumb.
  • TheReaper
    TheReaper Posts: 636
    Rear Projection TVs (I assume that is what you meant instead of Front) are not affected as much. Because they have three 7"->9" tubes (red, green and blue), usually towards the front center of the TV leaving space to the sides.
    If you are getting an effect from the sub-woofer, it would probably show up as a convergence problem with the color (red, green or blue) that is closest to the sub-woofer. If you want to test whether you have a problem or not, bring up the convergence grid, and then move the sub away, and see if there is any differance.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • raidical
    raidical Posts: 11
    edited January 2005
    Reaper,
    Thanks for the info. I performed the test you suggested and see no problems at all. Moved the sub right next to the TV while both the tv and sub were on and functioning and saw no difference. Thanks again for the input. By the way you were correct it is a Rear projection Toshiba.
  • keithelliott11
    keithelliott11 Posts: 3
    edited February 2005
    Hello-
    Are you pleased with the sound from this subwoofer?
    I'm considering one for use with a 5 speaker RM6200 setup.
    Thanks.
    Keith
  • raidical
    raidical Posts: 11
    Keith,
    I am very pleased with sw10 especially in the Home Theatre Arena but i have to say I would get somebody elses opinion on Music because I am not a "BASS" Man I prefer Good Music where Bass is not that prevalent and highs and mids are. Thanks.
    VR3 Posts: 29,700
    Whats ur budget for a sub?
    www.hsuresearch.com
    www.svsubwoofers.com
