Russ -
VR3
Here it is...
Faceplate... minty silver fresh...
I cant use a flash on the faceplate, because then you cant see any of it...
Here is the Side with the scratch, negative imaged so you can actually see it (its that light)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Here is the other side.. minty...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Here is the top...
Some reason this pic was really big in file size, so I had to decrease the color and make it smaller...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
And the back...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
