1986 cadillac
Systems
Systems Posts: 14,872
edited December 2004 in Car Subwoofer Talk
i was just wonderin what subs i could put in the trunk that sound nice but dont cost too much.....the car has a solid steel trunk wall between the back seat and the trunk, so i dont know how good they'll sound....any suggestions?
-jeff
Testing
Testing
Testing
  • Jstas
    Jstas Posts: 14,999
    Two Polk Audio DB 104 DVC's and a Hifonics Nemesis 750D mono sub amp. Wire the four voice coils in series for a 1 ohm load on the amp and you'll get 750 under-rated watts into those DB's. Build a ported enclosure and vent the ports though the rear deck, into the cabin and you'll have all the boom you want from probably less than $500 invested in your system.
    Expert Moron Extraordinaire
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    <--- cadillac king.
    I did two 8" 200 watt subs in the back of a 76 cadillac... put 180 watts rms to each... and BOOYA.
    What I did was cut a hole in theback deck (cut through the steel), and laid the factory back deck covering material (plasticy clothy crap) back over the hole so it didn't look like the hole is there...
    Then i built a box in the trunk, with the two 8's, and mounted it right smack under that hole... so thatthe subs fire up through said hole... I'll tell ya - for two little 25 dollar phoenix gold tantrum 8's - it pounds like hell...
    The Artist formerly known as PoweredByDodge
