Found a Tube tuner today
faster100
faster100 Posts: 6,124
edited December 2004 in Electronics
I found a Midland tube tuner today... was dirty and paid a buck for it , cleaned it up... cleaned the tuning coil and controls... works great!! Looks really cool.. however its MONo, anyway you can make it sound stereo? I am useing a Y adapter now and it sounds really good and improved the bass it seems to me.. is this possible? small, nothing fantastic, no magic knobs but works and that is cool for $1 dollar.. i want to paint the cover is all.. looks like some surface rust inder the paint coming through.. chasis is clean and all NEC tubes original.. don't know if they are worth anything, dont care as i will most likely keep it to play with for awhile.. will post pics shortly
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • faster100
    also, what is a MPX output? it has one..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaN
    RuSsMaN Posts: 17,986
    What the hell, I'm in a good mood.
    The MPX out is the 'Multiplexer' output. If you run a cable from it, to a Multiplexer (get a tube one if you can find it), the MPX will decode the signal into stereo, and have 2 RCA outputs.
    Worth, not much really monetarily, even the tubes - there are TONS of tuner tubes available, NOS, from almost any manufacturer. Worth, as far as cool factor goes, off the charts imo.
    Find a mono tube integrated (10-20w), and a single corner-horn speaker, and have a REAL vintage rig.
    Cheers,
    Russ
  • madmax
    madmax Posts: 12,434
    Can you buy just any multiplexer and plug it into that jack? So what happens, do you get left and right output out of the multiplexer box and then run that to an amp?
    madmax
    Vinyl, the final frontier...
  • faster100
    Cheers,
    Russ
    FWIW i appreciate it... Thanks..
    It sounds really good.. for what it is
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • gregit
    gregit Posts: 284
    Russ and f100???....It's a Christmas miracle!!! ;)
    mhardy6647 Posts: 35,047
    Actually, the FM stereo signal is already multiplexed... you need a MULTIPLEX DECODER :-) sometimes known as a stereo adaptor. And, yes, you use the MPX output of your tuner to connect the adaptor. The adaptor then provides the L and R stereo output line level signals for your amp/preamp/whatever.
    Yes, they are basically generic. I am partial to the EICO MX-99, but then I am generally partial to EICO stuff. The MX-99's tend to be pricey on eBAY, FWIW. There's a Heathkit model that's relatively plentiful (I got one for $5).
    Performance of ALL tuners (old and new, good and bad, cheap and expensive) is better in mono than stereo. Especially if you are in a fringe area, you're likely to be just as happy listening in mono IMO.
    If you're interested in the technology of compatible MPX stereo FM, here's a link with some info:
    http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/RadCom/part21/page1.html
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    God bless us, one and all... limp ....limp
    :D
  • faster100
    transformer **** on me tonight, oh well... the burnt smell is still giving me a head ache
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaN
    Oh man, you let the smoke out. That's a no-no.
    Probably, like most vintage tube gear that has sat a while, could have used a Variac. You should invest in one, they aren't terribly expensive.
    I will say it's strange that you had it at full power (turn on, plugged into the wall) and listened for some time without a problem. Usually, if caps or xformers blow, it's as soon as B+ hits.
    Hey, it will still LOOK cool sitting on the mantle or some such.
    Cheers,
    Russ
  • faster100
    i used it from around noon till 4:00 then again for awhile then it just stopped playing music, i smelled it.... starting pulling plugs.. plugged it back in in the kitchen, everything lit up.. tubes, light bulb... then alittle smoke.. turned it over and it looked like it was coming from the paper under the transformer... turned it off and placed it outside to cool off and air out.. the metal top on the transformer was very hot.. Its still not dead... i think its on its way though... I think i'll just scab the tubes, and display it. i would like to try a dynaco fm tuner though now... i liked the sound of this one today. Glad it was only a buck lost. i would change the xformer but most likely not worth it or available parts...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
