Carver Amps -
VR3
Hello Fine Forum Brethern!
I am looking for some 300 x2 Carver Amplifiers...
Whats some models numbers? recomendations? Etc Etc Etc
Post edited by VR3 on
M1.5t...older amp,very good though
tfm 45...a little newer
You usually see a lot of M series on ebay,and tfm sreries as well,not a whole lot of 45's though -
Thanks man -- I'll be keeping a look out...
Definetely looking to get a bit more power in the room...
Anyone need a B&K?
That 1.5 looks SWEET. Dosnt go for all that much. Hopefully Santa will be good to me!
Man that'd rock. Get some Polks and 300+ watts of Powa! :cool: :cool: I can do it! :cool: ... maybe without selling the B&K!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Having owned both the m1.5t and the TFM-45/42/m4.0t....I'd opt for the TFM-45/42/m4.0t
They sound better, IMO.
Thanks Troy,
I'll keep a look out for all of those...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Not trying to talk you out of more power, of course, but don't discount the 250 W/ch TFM-35. I've got a m0.5t, a TFM-35, and a TFM 4.0 (which is the same basic amp as a m4.0t and the TFM42/45). I feel like they're all good amps. The TFM-35 is my personal favorite. It's never even come close to running out of power driving any of the speakers I've got, just barely even gets warm, and is dead silent when no signal is playing.
Jason -
I think 250 is adequate and will be a consideration, just depends on what happens...
Thanks for all the replies- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I've owned the m1.5t but upgraded because my Martin Logan CLS electrostats would send it into clipping at will. I went with the A500x (good to 2 ohms) which worked very well. I later got a A760x (good to 1 ohm) for the CLS's and moved the A500x to subwoofer duty.
It looks as if I will be getting the TFM 45...
Any thoughts on that amp?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sid- shoot me a PM if you decide to unload the B&K. I'm not that far from you.
edited- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sid, I enjoyed every moment listening to my TFM-45. It fell victim to a lightning strike last June and if it weren't for that, I would still be enjoying it right now. Good luck!Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! ) -
Yep, I have heard good things about Carver (as well as bad things, lol)... Hopefully I will like it...
SIMM -
You got a PM...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
