digital coaxial cable
dholmes
I need a long digital coaxial cable & was thinking about making my own, isnt the coaxial cable just 75 ohm cable like you use for tv with rca ends? I tried to use audio cables & it wouldnt work. My pre-pro stated that I should use coaxial cable only. thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
http://www.epanorama.net/documents/audio/spdif.htmlCabling details
S/PDIF (IEC-958) uses 75 ohm coaxial cable and RCA connectors. 75 ohm coaxial cable is inexpensive, because it is the same cable as used in video transmission (you can buy a video cable with RCA connectors to connect you S/PDIF equipments together). Coaxial S/PDIF connections work typically at least to 10-15 meter distances with good 75 ohm coaxial cable.
Also important is the wire core:The coax used should have a pure coppercenter conductor (no copper coveredsteel or aluminum) and have good braidcoverage (90% or more).
http://www.epanorama.net/links/audiodigital.html#spdifWin7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
You can for a cheapie / quickie fix is use RCA video cable. Video cable is the one being yellow its impedance is 75ohms so it should work.
Maybe not the best cable, but I don't think it will hurt anything. Been using one for 4 years now with my DVD player myself.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Thanks everyone, I used a good audio rca cable & it would work fine for about a hour & then it would start cutting out. Ill try your ideasMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
