center channel to compliment Monitor 10s
I have just come into posession of some nice Polk Audio Monitor 10 front speakers and need to pick up a center channel speaker to match them. Does anyone have advice or suggestions on which speaker would be best? Thanks!
Post edited by zenyatta on
Welcome to Club Polk!
I'm pretty sure you know this, but, Polk did not specifically make Center channels for their old Monitor series, would it be unreasonable for you to use a vertical speaker (as opposed to the popular horizontal format for todays current centers) for your center? If so you can easily timbre match with another (old) Monitor Series speaker,
Good luck in your audio pursuits,
Matt -
Using a vertical speaker isn't something I had considered so thanks for the idea. That type of speaker, however, won't work in my HT configuration so a standard center channel speaker is what I need.
Any idea which model would be best matched to my fronts (Monitor 10s)?
Alex
