f/x500i
johnnyboy
JUST RECIEVED MY POLK 500I REAR SPEAKERS. CAN SOME ONE TELL ME WHERE THE DIPOLE/BIPOLE SWITCH IS? THE MANUEL SHOWS IT IS ON THE RIGHT SPEAKER. WELL UNLESS IT IS INSIDE ,ITS NOT ON MINE. HELP PLEASE, THANKS
Post edited by johnnyboy on
Any chance you got two left speakers? Switch shouldn't be that hard to find. Mistakes happen.
"I'm not a man for all seasons, but I'm doing something right."
FZ -
HOW DO I KNOW IF I HAVE 2 500I LEFT SPEAKERS? SERIAL #RC 05574 AND LC 05574. R FOR RIGHT-L FOR LEFT? STILL NO DIPOLE/BIPOLE SWITCH IN SIGHT.
Pop the grilles off, should be fairly obvious.....
Cheers,
ARE YOU SURE? DONT WANT TO SOUND LIKE AN IDIOT, BUT HOW DO I POP GRILL OFF WITHOUT DAMAGE? APPLIED SOME PRESSURE BUT NO LUCK.
THANKS RUSS GRILL OFF SWITCH THERE.
the sreeal # tells youthat the rc is the right one and the lc is for the left the way i take off my grills is i get a sheet of paper and fold it in half then slip it under a corner and gentley pull the grill off. when you mount them on the wall the switch should be on the inside the mid bass should eather be faceing forward or twards the outside wall if you put the rc on the right and the lc on the left.
any one know how i can get the little stick on logos for the front of my fx 500i i want 4 more so the logo is on both sides of my suround. -
this may be it:
RT Bookshelf logo ea RF0259-1 $1.00 $0.80
call polk to order. -
goingganzo, let me know what you find out on them logos that is a good idea.
Where's the switch? You're killing me.:) -
THE SWITCH IS INSIDE THE GRILL OF RIGHT AND LEFT SPEAKER
