Headphone interface help?
![steveinaz](https://us.v-cdn.net/5021930/uploads/userpics/2VS86EURLEUB/nNOY901PG0TA8.jpg)
steveinaz
My current preamp doesn't have a headphone jack, but I'd like to add a headphone output. Does anyone make a "box" that connects to preamp outs for the purpose of connecting headphones? I know there's dedicated headphone amps, but I'm looking for a simple converter of some kind...
Post edited by steveinaz on
A headphone amp is about as simple as it gets. Do you mean cheaper, smaller, battery powered? I'll bet there is a headphone amp out there somewhere meant for boosting power out of the cheapie mp3 players or cd players. Sorry, don't know of any particular ones.
Max,
I think you're right, looks like a headphone amp is about the only way. My CD Player has a headphone jack, but the level control is manual, which means getting up all the time to change volume. I'd rather run something thru my pre so that I can use the remote volume control.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
I was checking that out. I think I'll just scope ebay for the Creek headphone amp, it has a remote volume control.
Thanks for the assist!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Well there is a workaround, Sennheiser makes a headphone extension cord with volume control (HZR62)...$29 bucks. Cool.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
