Cobalt Cable vs signal cable
georgegedulin
georgegedulin Posts: 14
Im deciding what to hook up my lsi9's with. I am looking at the cobalt ultimate cable as well as the signal cable double run, price is almost identical but i see that resistance per 1000ft is 4.5 ohms for the signal cable and 1 ohm for cobalt cable (that is the claim anyway) is one cable any better than the other?
thanks
polks soon
Post edited by georgegedulin on
  • Willow
    Willow Posts: 11,310
    edited December 2004
    which fruit is better apple or orange....why I say that is we have no way of knowing if the test were conducted using the same equipment....everyone will tell you try em out and see which you like better
  • dbournival
    dbournival Posts: 131
    I have the Cobalt Cables, they seems to work very well on my #2 system. Much better than the Home Depot 12 gauge (made by Carol) or some 20 year old orogional Monster Cable. I have never tried any of the Signals...
    Here is a link to a review of the Cobalt (and others) see what they say vs Cobalt's claims:
    http://www.audioholics.com/techtips/audioprinciples/interconnects/SpeakerCableFaceoff.htm
  • PolkThug
    PolkThug Posts: 7,532
    You will hear a slight difference with the 1000 foot run.
    Regards,
    PolkThug
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Regards,
    PolkThug
    Dang, you beat me too it... Unless you are running huge lengths, you should notice very little difference.
    The difference in their shielding would be more of a worry (assuming there is one)
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • georgegedulin
    well, i went with signal cable double run, lots of great reviews from good sources, im only running 6 feet so im sure it will sound good no matter what.
    polks soon
  • Whadyasay
    Whadyasay Posts: 300
    Here's what I ended up using for my bi-wired LSi9's and LSiC center.
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-590
    It uses the same high-strand OFC copper cable as most quality 12 GA speaker cable, it is very easy to cut/terminate, twisted conductor format, more flexible and easily shaped than PVC-coated cable, and hides very well due to it's black jacket. It's also way cheaper than anything your likely to find in 4-conductor 12 GA/ea. cable out there.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • dorokusai
    dorokusai Posts: 25,576
    If you are running any length <1000ft, you will notice no difference with this bracket of cable.
