Opinion - Best Connection: F to RCA or RCA to RCA
JRaddo
I ran rg-6 to accomodate audio signals for several 100' plus runs between audio components. I will use wall plates to finish off the cables. However, I am curious as to whether anyone believes I should use an RCA connector on the RG-6 cable (and an RCA to RCA feed-through on the wall plate) or F connect on the RG-6 cable (along with an F to RCA feed-through adapter on the wall plate). Does that answer change where component video is being transmitted over RG-6?
Due to the way that the RG-6 lines were terminated, use of the feed-through is not optional.
Post edited by JRaddo on
I'll thinking about the same thing, long RCA runs using RG-6.
My take on this would keep it RCA all the way. Why not it's just audio right so why change back and forth.
And BTW Welcome
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I guess the first question is what connector works best on RG-6. My initial thought would be F-connectors (because that is what the connector is designed to do), but I don't know. The second question would be which adapter (the F female to RCA female or RCA female to RCA female) will degrade the signal less.
I may just try both and see if there is any cognizable difference.
But, I would still love to hear from anyone who has experience with this. -
Are you going to connect the RCA jacks with solder? If yes I say go direct to RCA from the RG-6 cable. RG-6 cable is designed for the F connectors thats true, but if soldered then anything could be connected.
Question, just how long is this cable run?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I have not decided on the solder. Strangely enough, I have read posts that say soldering is good and posts that say soldering is bad. Tough to know what to believe.
Anyway, the longest run I am dealing with is approximately 150' and then I have some that are 75' and 50' or so.
An additional issue I have with terminating the RG-6 with RCA jacks is that the space in the outlet boxes will get really tight with the bigger RCA connectors. Of course, if I could determine that one method is better than the other, I would make the effort. -
Well I think you know where I stand on this soldering thing. Solder Solder Solder. I never done this myself with RG-6 but plan to do just that in the future, and I can't see any problem with the room for RCA jack wall plate.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
