what speakers with 6.1 or 7.1
jdog1
if i get a new reciver that is 7.1 what rear speaker would you get
my current
cs400
rt800's front
rt55's rear
would you use55's on the side then 55i's in the rear or 35's and use the 7.1
or just get 1 cs400 and do 6.1
ps... i only want direct raidial no bipole dipole in my system
i think good rears are important thats why i have 55's now.
The way i see it its a pefect driver match without going
all rt800's
are they not going to make the 55's or a new model of the 55's
my current
cs400
rt800's front
rt55's rear
all rt800's
Post edited by jdog1 on
I'd go 35i's for your side surrounds, I'm not sure you'd need 55i's for that type of duty; plus, then you'd have another RTi model to talk about. Yes, looks like the 55i has been dinosaured.
if you are going to keep the rt55i's as side surrounds, i would use 2 rt35i's as surround center speakers. one cs400i would also work, but if you have the 7.1 capability, i would use it...
