Seperate Dac - ?
VR3
The thought of a new CDP has crossed my mind, however - I don't believe I will be able to purchase one anytime soon, so I am looking for the next best thing, right?
Basically I am looking for a dac that is 50-100 dollars that will make my Denon DCM-280 sound better!
I dont know what kind of Dac the Denon uses now, but hopefully someone does and can help me out here...
50-100 dollars shipped to my door, anything in that range?
Post edited by VR3 on
The Denon has dual 18 or 20 Bit Burr Brown's if recall correctly. You aren't going to find anything for under $200 that is going to be a substantial improvement.
Cheers,
Mother effer... LOL
Ok, well what do you think would be better suited?
1) Better CDP
OR
2) Better wiring? Power cables, IC - etc- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
#1...just my .02Outlaw 990 Processor
Outlaw 755 Amp
Denon 2900 dvd-sacd
Dishnetwork HD-Dvr
55" Sony LCD RPTV
Lsi 9-fronts
Lsic-center
Rt55i- surrounds
Velodyne cht-10 sub
2007 Dodge Quad cab
Kenwood Excelon KDC-X891
JL Audio 300/V2
Polk Audio SR 6500 - Fronts
Polk Audio DB651 - Rear
2 -10" Treo Subs
Interfire IB 2600C sub amp
Sirius Sat radio
Ipod connection -
Time to try a single disc player/transport.
Depends on how much money I come across in the next while...
Cambridge Azur 540!!!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Originally posted by Vr3MxStyler2k3
Mother effer...
watch your language young man.
My Audio Research Lab DAC5 sounds real nice:D
Twin***WAREMTAE*** -
Ha!
Or maybe....
AMC CD8b
Isnt there a NAD player out there comparable? Anymore...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I've read about a lot of people getting good results with this DAC. A lot of them are modifying them though. You can find used ones at audiogon for around $100.
http://www.zzounds.com/item--ARTDIOSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
The NAD C541i is a very nice player.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
DCM-280 has the Burr-Brown 18-Bit D/A Converters (PCM-1716), my Denon DCM-380 has Burr-Brown 20-Bit D/A Converters (PCM-1748) which sounds pretty good to me.
The Denon, don't get me wrong....
It is a great player - but I am getting rid of the weakest links in my system, and the Denon is the weakest component. After I address it - I plan on upgrading the power cables on the components, doubt I will upgrade ICs and speaker wire...dont find it worth it, bleh...
Thanks Steve, will give that one a look...
Are the old Cambridge CD players the D300 and 500 (or whatever) as good as the new 540 and 640?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
http://cls.audiogon.com/cgi-bin/cls.pl?dgtlplay&1108213395
If you can find an older Meilor Bitstream DAC from Museatex grab it, it will still destory most digital gear made today for under $3k in its Upgrade II form. They sell used for about $300. If not grab the Rega. -
Ha!
Or maybe....
AMC CD8b
DCM-280 has the same DAC as AMC CD8b. AMC might still sound better if it has better clock and OP Amps-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
If you go with the "SE" versions. Don't waste your time with the D300SE, get the 500SE--hell the 500SE goes for under $200 on Ebay typically. One sold about a week ago for $179, and it was mint.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Start hunting them down, Sid. You probably won't find something better but the sound will definitely be different. I had a lot of fun with my Audio Alchemy stuff. Less detail than my NAD but a lot of bloom in the mids and powerful bass. Take a look at jitter reducers too. They help quite a bit.
Maurice
