How would I incorporate a preamp into my HT
Codey
Codey Posts: 188
edited December 2004 in 2 Channel Audio
I'm thinking about adding a preamp for 2 channel music to my home theater but I'm having a hard time trying to figure out how it will work. My receiver and new preamp are going to have to share amps, and the only way I can see that working would be an excessive use of Y jacks (even more if I want the sub in there). Is there something I'm over looking, an easier way to do this without doing a seperate system?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
Post edited by Codey on
    VR3 Posts: 28,820
    Sadly it dosnt work that way...
    (atleast not for me) -
    When I tried a y splitter between preamps to the amp - I had NO volume on any preamp...
    I have to shut down, unplug, then plug up the other, etc to do different things - kinda annoying - but in the end I think it is worth it...
  • Codey
    Codey Posts: 188
    Bummer.
    You'd think by now a company would have have recognized this need and addressed it with an aproppriate product.
    So if you just swap cables about, do you use splitters to hook up your sub?
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
    VR3 Posts: 28,820
    Nah, I just plug up the sub as well while I'm at it, one more cable dosnt hurt --
    You could always use the speaker wire method though...
  • TheGrayGhost
    TheGrayGhost Posts: 196
    You could use an A/B switch box from Radio Shack. A manual switch box cost ~$15 and a remote controlled switch box for ~$40.
    Best Regards, Cliff
  • Early B.
    Early B. Posts: 7,900
    Look into an amp selector such as the Niles Audio DPS-1.
    "God grooves with tubes."
  • tryrrthg
    tryrrthg Posts: 1,896
    Read THIS THREAD I started over at the HT forum on this topic. Although I decided not to go that route (I'll have 2 seperate systems eventually) the thread was very helpfull.
  • Codey
    Codey Posts: 188
    Thanks for the help guys. The preamp I have in mind doesn't have HT bypass so I guess I'll just take the time to switch cables around, which isn't really that big of a deal.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • tryrrthg
    You don't have to have HT bypass.
    attach the preouts of your reciever to an input on your 2 channel pre. when you watch a movie you select that input on your 2 channel preamp. with this hookup option you'll have two volume controls in the mix. You'll have to calibrate your 2 channel preamps volume control with your HT speakers. Whenever you watch a movie you just have to return your 2 channel pre to that volume setting and then use your receiver to control the volume from there.
    The easist way to do this is just set your 2 channel preamp to 12 o'clock, then calibrate your speakers the same way you would if you were running just a receiver
    VR3 Posts: 28,820
    I dunno bout you, but I would rather unplug stuff than eff with two volume knobs... loool
    I have cables run from both preamps, for a fast connect/disconnect. I have poor quality cables running from the HT preamp though
  • Codey
    Codey Posts: 188
    That was my thinking too as this setup has to be girlfriend friendly.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • tryrrthg
    you don't have to eff with two volume knobs you just have to know where to put your 2 channel volume control to calibrate it with the HT receiver. Figure that out once, and it's a breeze after that.
    Unhooking things is NOT girlfriend friendly!
  • Airplay355
    Airplay355 Posts: 4,298
    run two different sets of speaker wire and plug in which ever one you want....1 for 2 channel and one for home theater....thats what im gonna do
    VR3 Posts: 28,820
    That is a good idea, to bad I have a preamp for my HT!!! ARGH!!!
    I need to sell this POS.... Only time I missed my PE is right now! lol
    But if he has two preamps, the speaker wire thing won't help
  • Codey
    Codey Posts: 188
    I might be interested in HT preamp if you really want to sell it.
    If I get a preamp for 2 channel I'm just going to swap cables instead of more speaker wire and dealing with two volume controls.
    I would have to eff with two volume knobs because I don't watch TV or listen to movies at a consistant volume. It all depends on what I'm watching, who I'm watching it with and what kind of mood I'm in.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
    VR3 Posts: 28,820
    The HT preamp is Pro Logic - are you sure you'd want it!? lool
  • Codey
    Codey Posts: 188
    Oh.... I'm good thanks.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • tryrrthg
    No, you wouldn't have to mess with two volume controls. Whenever you are using the HT set up you just have to return the volume of your 2 channel pre to the 12 o'clock position (or whatever volume setting you need it to be at to calibrate it with the rest of your HT speakers), once that is done all volume controls will be done through your HT receiver.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Did this suggestion get overlooked???
    I've used on of these before to compare receivers and it worked great. This seems like the simplest solution....
    You said "You'd think by now a company would have have recognized this need and addressed it with an aproppriate product."
    Someone has, it's this Niles unit...
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Personally, I liked the radio shack switching box. For $15 all you do is push a dang button for the switch. Of course you would need 2 more pair IC's (Assuming analog out on the DVD)
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Codey
    Codey Posts: 188
    I guess the selector box option did get overlooked. I just looked at the Niles stuff and it does seem to be the simplest solution.
    I was in Radio Shack yesterday but couldn't find anything that would suit my needs, they just had speaker selectors.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • Codey
    Codey Posts: 188
    Okay, I get it now. I just reread that thread you linked and it makes perfect sense now. That would appear to be the easier and cheapest solution to setting this up. Thank you.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
