Mixing amp brands
Codey
Is it very important to stick with the same type of amp? I can get a NAD 216THX locally for a decent price, but I'm wondering if it will mesh well with my current setup. Any help would be appreciated.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
Post edited by Codey on
Depends on how your using it. If you're going to drive a sub, I'd say no. Same if your going to biamp w/ it, or use it for surrounds (unless your going multi channel music, then the surrounds might not be kosher).
Amps have a signature sound, too. Some have good low character, others may be stong in the upper freqs. Transparency, brightness, depth, yada yada.
I definitely wouldn't mix them in a bridged mono set up, but you should be able to mix and match. The best thing is to try it and see if it suits you... -
I was thinking of using it to power my RTi8s. I'm powering my center with the GFA-2535 bridged and just thought that because these amps have different sound characteristics that it might not sound right.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
Codey, although your speakers are in the same series, they are still totally different animals. I'd certainly mix it up a bit. Try it out and you might be suprised what you hear.
I've always enjoyed NAD on Polk.
Cheers,
How do you like the 216THX specifically? I was thinking about that or maybe trying to find a Rotel RB-980BX or a RB-990BX.
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360 -
I use both NAD and Adcom amps and the combo works perfect with my Polks.
Smooth, Clean, Warm and Silky Sweet Sound.
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
