Voice Match RSi38 w/CSi3?
Last year, my brother and I purchased a set of RSi38 speakers for my parents. While I made attempts to talk them into purchasing a center channel (they didn't care about surround sound), they thought that having the two speakers was enough.
About seven months later, they finally decided that they wanted to find a center channel. According to the Polk website, the recommended model is a CSi30, which is discontinued, and apparently, hard to find. Would a CSi3 or another comparable current model work fine with voice matching, or should I start scouring the usual places for a good used CSi30?
I appreciate all of the help that you can offer.
Post edited by DGibFen on
CSi30 can be found on EBay for a good price, but the CSi3 will work ok...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
