I was tightening some screws
VR3
VR3 Posts: 28,775
edited December 2004 in Speakers
Yep, I was tightening the screws on the only speaker I hadnt tightened, dunno why I didnt. I could turn them a good twist of the wrist too - hmm, wonder if this will change the performance...
The inside of these speakers are interesting, I wonder how they look all the way down -- hmm...
The driver arrays are seperated, I am guessing them join back together at the bottom at the long port, I am not sure...hmm
But let me see here...
Wooooooooofer
Post edited by VR3 on
    VR3 Posts: 28,775
    Tweeter magnet...
    And no, these speakers are not shielded...
    I wonder why they used gold terminals on the woofers and not on the tweeters???
    VR3 Posts: 28,775
    Man this is weird...
    I opened up the BP6B - completely different speaker...absolutely nothing the same..
    More questionable is they say it uses a TL design...but this is most definetely a standard vented enclosure??
    VR3 Posts: 28,775
    The tweeter is different, the magnet is about half the size -- .... wth
    VR3 Posts: 28,775
    The drivers arnt seperated like they are in the BP10B
    Interesting...
    One must remember this is only a 600 dollar speaker though...
    VR3 Posts: 28,775
    Woofer/Tweeter in cabinet...
    Woofer uses a cloth cone, rubber dust cap and surrounds - Cast Magnesium basket, etc..
  • Early B.
    Early B. Posts: 7,900
    Sid -- are you implying that you expected to see better build quality in your Def Tech speakers?
    "God grooves with tubes."
    VR3 Posts: 28,775
    No, not at all.
    The fact the BP6B is like 10" shorter than the RTi70 and weighs the same exact weight tells me they are built fine.
    What I am implying is, they say it is a transmission line, in which it is indeed not...
    (unless I am going blind over here) --
    The BP6B is built like a tank, hands down...just kinda strange up to the design...
    As for the parts, I was told Definitive used the same tweeter all around, in which - it is not. But this is no big deal.
    Bottom line is, which sounds better...
    And which one is still here? ;)
    I didnt expect it to have steel walls or anything, its only 600 a pair...
    It uses 1" thick Medite front and back panels...
    Rock solid yo!
    VR3 Posts: 28,775
    Now if my BP10B had a build like this, I'd be PISSED!
    I find it funny how the designs differ though...
    The Passive Bipolar line has been in production in 1996, still sells strong, etc -- no plans of changing it...
    The BP6B uses longer screws, different padding - I dunno if fiberglass has any advantages over foam (thick thick foam BTW) -
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Those speaker wires just laying across the braces probably resonate something terrible.:D
    I would think some wireties would be in order?
    VR3 Posts: 28,775
    Waaaaa, I dont think so...lmao
    I wonder what the crossover looks like...HMM
    VR3 Posts: 28,775
    BP10B Crossover...
    VR3 Posts: 28,775
    BP10B - Inside...
    Fiberglass insulation up top between the drivers and the long 3/4" thick brace...
    Then a really thick foam pad lines all sections of the lower enclosure...
    Gigantic port (blocking the camera)
