Connection?
Pinktulip7
What kind of cable wire do I need to connect my dvd player with HK AVR 7300?I ment audio and video?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
several different ways to connect your dvd player to your HK.
for audio first.
you can go with a digital cable to your HK. Two types of digital cables are out there. Optical and coax. Both do great jobs.. both sound the same.
and cost about the same too. YOU NEED A DIGITAL CABLE TO GET 5.1 DIGITAL SURROUND SOUND.
OR
if you just want two channels of audio from your dvd player.. then you would use a left and right RCA cable. called an interconnect.
Video:
lowest quality is a composite connection. The composite cable looks just like a RCA audio cable. it's the lowest possible quality of video. There are better options.. so unless that's all your HK has.. don't even use this one.
Next up in quality is S-video (SVHS) this is much better than composite. Lots of people use this. the cable is exactly what it is.. one S-video cable with a small multi pin connection on both ends. They start about $10 and go up from there in price.
Finally. You have the best and highest quality of video. component video. This uses three RCA cables. red, blue, green. it seperates the video signal into three cables. Resulting in the cleanest and sharpest best damn looking video quality.
if you have any more questions. come back and we'll hook ya up.
good luckPolkFest 2012, who's going>?
very thorough Danger
I bought optical cable for audio,thanks.TV :>Panasonic TC-P55VT50
