Musical Instruments Power AMP???
doggie750
Can this be used for HOME theater purposes? If not WHY? Thanks
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Oh no.....I can just see my wifes face now with a bank of Marshalls across the back of my HT!
But seriously, I'm not an electronics whiz but I think an amplifier is looking for an input signal within a specific voltage range, i.e. 1.5mV or whatever, so I guess it depends on the amps input sensitivity (if that's what it's called) and the preamps output voltage?2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Many of todays modern guitar amplifiers (Marshall is just one) actually have audio inputs for connection of source devices such
as a CDP for practicing/performing. -
Actually, I think he meant something more like this:
PA amplifiers. I think they should work just fine, but you should double check voltage ratings for both your preamp and these power amps and try to match 'em up.HT Setup:
Pioneer VSX-D912K
Polk CSi30 Center
RM6005 Satellites (Fronts/Surrounds/Rear Center)
Nameless 10" Sub
