sub & av hookup
johnnyboy
my system -sony str-de945-polk rt800i-f/x500i-cs400i-velodyne ct120 sub.my main question, receiver has 2 separate sub outs[not right-left] my sub has a right and left in[both rca type] how should i connect? i am using one sub out from av to left in on sub. seems to work.is there a better set up? also help on settings for av and sub. ie;low pass crossover 120-140,phase switch 0 or 120,internal xover or direct,high pass crossover 80-100? any help would be great. thanks
Post edited by johnnyboy on
Usually the sub has a default plug (mine is the left channel). I just hook up the single line, and it works really well. No difference if I attach the right.
As for crossover, I leave it deactivated. My AV receiver already has it crossed over depending on the other speaker setups (big speaks, 1 setting...small speaks, another setting). The only thing I mess around with is the subwoffer levels. I usually bring it down for music, and crank it up for movies...Movies have the extra coding for the sub.
I don't have your specific sub...so someone else may have a rebuttal. -
here is some good reading material......
http://www.polkaudio.com/home/faqad/advice.php?article=bassmanage
ultimately, there really isn't a "right" or "wrong" way....whatever sounds best to you, don't be afraid to experiment.
TroyI plan for the future. - F1Nut -
You need a Y-cable to hook your sub from line level to LFE.Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
boy the 800 500 400 velo is very popular how big is your room? i have the same setup and my room is 25 by 15. dues it say what the sup outs are in the manunel? if you have 2 of them all you need to do is get a y cabble and a sub cabble and hook the sub out to the cabble it might not matter then use the y cabble to hook to the velodyne and turn off the x-over on the sub and have fun.
