Revinyl job and other mods...
VR3
VR3 Posts: 29,440
edited December 2004 in Speakers
As many of your know, I let my Mom use my spare speakers, the powerhouse Pioneers ;) in the den - and...
When I got them, they were beat up to hell, so my Dad and I revinyled him.
When I say my Dad and I, I mean my Dad because he 'took over' and did it himself.
Well his method sucked. Period!
So, I am stripped the vinyl off of one just to see how easy it would be...
So, I have some questions. Do I need to cut individual panels of vinyl wrap, apply - then trim, for each piece? And just put a straight edge on the edge of the speaker to guide the razor?
Thanks...
I also plan to put some foam gasket material around the drivers and ports...
Here are some pics...
Post edited by VR3 on
    VR3 Posts: 29,440
    Here is the crossover...can you call it that?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I don't know that I'd dump much more time or money into those things.
    Looks like they could use some better damping internally off hand. How wide is the vinyl? I'd wrap the front, sides and top - and spray the back / bottom black.
    Cheers,
    Russ
    VR3 Posts: 29,440
    I also plan to remake the grills because my Dad made those as well, and like the vinyl job - it sucks...
    So, any tips on making a grill?
    VR3 Posts: 29,440
    Cheers,
    Russ
    One sheet can wrap both speakers, sides, front, top...
    I plan to spray paint the bottom, I spray painted the back last time...
    Damping is a good idea...
    Do you have some of that Dacron?
    I agree with you, They arnt worth much more time or money. I just wanted to get them presentable, and worthy of a spot in the den.
    The vinyl isnt much, and I plan to order the foam material for my line array...
  • RuSsMaN
    I'm not sending you any more Dacron, you know what it is, hit the local fabric shop and pick some up. It costs more to ship the stuff, than for you to just go buy it.
    Cheers,
    Russ
    VR3 Posts: 29,440
    Alright, I was more so asking if you would sell some and include it in that big ol box...hehe
    Either way...
    I will find some..
    muahahahhaha
  • izafar
    izafar Posts: 819
    Sid,
    Partsexpress has a pretty good instructions article on how to apply Vinyl/Vaneer on speakers. Just search for spome vaneers and you should get a link to that article.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
    VR3 Posts: 29,440
    Thanks Iza! I will definetely take a look and see what PE has on their site...
    Today, I tired my hand at making a grill frame.
    And yes Russ...
    I started your speakers! ;) I got the sides and back on one - should be done in 2-3 days.
    They turned out VERY good, I'm surprised.. (the grills)
  • madmax
    madmax Posts: 12,434
    Are those K-Mart shoes??
    madmax
    Vinyl, the final frontier...
    VR3 Posts: 29,440
    And if they are?
    Do you have a problem with K-Mart shoes?
    HUH HUH?
    These are my work shoes man...
    Steel toe, water proof, the works...
    My other shoes are NOT K-Mart shoes ;)
  • madmax
    I thought they were. :D
    madmax
    VR3 Posts: 29,440
    *blank stare*
    You have WAY to much time on your hands (which is obviously spent at KMart) ;)
    I actually think these came from Walmart...
    is there a difference?
    VR3 Posts: 29,440
    They turned out freakin good man...
  • gatemplin
    gatemplin Posts: 1,595
    The grills turned out well Sid. I dont know why you bother with those old things but to each his own.
    Graham
    VR3 Posts: 29,440
    thanks
    My mom is using them in the 35x15 den...(I want her to use good looking stuff, not some beat up speakers, ya know?)
    and they are my spare speakers that I haul around to parties, a DJ system if you will.
    Plays loud, takes abuse...perfect. I let my friends borrow them, etc...
  • madmax
    Looks good! Now you need to try some veneer work. Our local Lowes has unfinished stuff in a roll that you iron on. Real wood. I wonder if you can use a router to cut edges after you put veneer on wood? I've heard you can cut it with a sharp knife.
    madmax
    VR3 Posts: 29,440
    Veneer is WAY** to expensive for these speakers... LOL
    Maybe a different project, another day...
  • gatemplin
    madmax
    Real wood veneer is nice. You can use a flush trim router bit which works great if it is really sharp. You can also flip the speaker over and cut off the excess with a knife but this is harder to do than using the router.
    Graham
  • audiobliss
    audiobliss Posts: 12,518
    man, Sid; those are some HUGE speakers!!! What's the size of the woofers in those things?! How low can that thing dig?! Look pretty cool to me.....
    The grills did turn out pretty nice......good luck on the re-vinyling....`
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    VR3 Posts: 29,440
    They use a 12"..
    Might hit 40-45hz strong...
    They can play continuous volumes of 105+db, easy...
    They are 95db or so nominal..
    Just insanely loud speakers...
    VR3 Posts: 29,440
    Here is what they USE to look like...with the bad grill remake and vinyl job...
    It is really hard to tell by that picture...
    But like there are no distinct edges of the speaker, the vinyl wrap didnt 'cut' sharp enough...
    and the vinyl wrap over-laps in several places...I dunno, its just a terrible job
  • Airplay355
    Airplay355 Posts: 4,298
    those...huge....haahaa
    VR3 Posts: 29,440
    Yeah, they are actually pretty smalll..
    12" deep, 15" wide, 36" tall...
    Cheap cabinets, 1/2" thick particleboard...
    The inside of the cabinet wasnt even sealed. I had to run caulk all throughout the cabinet...
    I am going to get some velcro to attach the grills this time. Those grill guides/pegs I got last time was a freakin joke...
    But these grill frames I made this time are ALOT better than the ones they had before...
  • audiobliss
    Oh; they looked bigger in the picture. You know what they say, everyone gains 10 pounds on TV/pictures.....LOL
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
