Onkyo TX SR602 vs. HK AVR 235
rodman
Hi
Which of the following would be the best match for my Polk RM6900 speaker package ?
Onkyo TX-SR 602 or
HK AVR235 ?
others ? (wanted to stick to 7.1 AVR's for future use)
Thanks for your opinions/expertise.
Rodman
Onkyo TX-SR 602 or
HK AVR235 ?
Rodman
Post edited by rodman on
IMO the Onks are easier to use than the new HK's. I sell both.
Regards,
PolkThug -
Originally posted by PolkThug
I sell both.
Regards,
PolkThug
which sounds better Toby? All processors are not created equal as you know...
HBomb***WAREMTAE*** -
HBomb
That's a tough one. I don't have a good way to A/B receivers. FWIW we use Onkyo's to power the bigger speakers.
Regards,
PolkThug -
I'd go with the Onkyo, HK has reliability problems lately.
If you can, listen to both to see which you like better.
Based on my Onkyo TXSR501 and HK AVR630:
- Onkyo is more user friendly
- Onkyo has a wide flat response, which depending on the speaker used, may sound harsh on the highs.
- HK is a processed sound
- HK response rolls in on the lows, has a blip in the mid highs for vocal clarity, then rolls off. Which depending on the speaker used, may sound bright or warm.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
You've measured this somehow? -
That is the way it sounds to me. If you play with an equalizer in your system, after a while you can get a sense of the effects of boosting and squashing frequencies.
TrueRTA also shows the same pattern, but I would have to negate the effect of my speakers (and other things), to measure what is from the receiver.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
