Computer Fire....
Demiurge
Demiurge Posts: 10,874
edited March 2024 in Clubhouse Archives
My MOBO started on fire last night! (I'm at work right now posting this). I went to the parts store and got a new MOBO. I installed everything at work, but have no way of testing it till I get home. Thank God for having a window on the side of my computer so I could see it happening. Could have been a disaster had I not been home. :(
Has anyone else had something like this happen? I'm pretty proficient with computers and have never heard of this, but the guy at the computer store seemed to have heard about it a lot....:eek:
  • Willow
    Willow Posts: 11,220
    edited December 2004
    YIKES !! you didn't ask the cumputer guy why this happens ?
  • faster100
    faster100 Posts: 6,124
    "alot" i wouldnt say that, he wanted the sale.. LOL with no real answer for ya,
    I powered up my at the time bedroom pc, and the power supply popped and caught fire for a sec followed by the stink of burning electronics.....
    bad thing is when a power supply or board go's that bad , it takes the rest with it.. I lost my memory, hard drive and processor.. only thing that still worked was the pci cards and the cd/ floppy drives so good luck..
    ive been building computers for some years now and it happened one time.. so its not normal, but anything can fail
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • dcarlson
    dcarlson Posts: 1,740
    A few weeks ago, I had a friend's system over for a reformat. When I plugged it in all I heard was a LOUD pop, a whole bunch of smoke and an awful smell. I won't take people's computers for free any longer. The thing was caked in dust and I'm guess the move shook up the dust and shorted the power supply.
    My advice is to shut down your computer when not in use. That way there will minimal dust build up.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • Mjr7531
    Mjr7531 Posts: 856
    Caught on fire? Was the thing over clocked? Are all the heatsinks attached where they should be? I've heard of a computer going up in smoke, but not fire...
  • nadams
    nadams Posts: 5,877
    Dust should not short anything out, unless there are little metal flakes being sucked into the computer.
    You could probably witness a small fire if the caps on the mobo went. When those things go, they actually produce a small amount of hydrogen gas, which can ignite. Usually all you'll get is a *bang*, but sometimes the crack in the cap is small enough that the gas slowly escapes and can appear to be on fire.
    A lot of mobos have been produced with bad caps (see www.badcaps.com for more info)... the only option is to try and replace them yourself (some tricky soldering work) or just replace the board.
    Also, a dead mobo or PSU will not always kill everything else in the system. I have experienced my mobo dying, and killing my PSU, but everything else stayed intact. I have also experience just the mobo dying and everything else being fine. In fact, both situations happened on the very machine I'm typing on :-).
    Demi- make sure that your mobo wasn't still under warranty....
    Ludicrous gibs!
  • Demiurge
    Well...
    I got the last parts I needed and finally had the time to work on it and I was able to fully recover my entire system. I just did a fresh install over my existing version of windows. I have ALL of my mp3s, pictures, files, ect...
    I'm very pleased. I'm getting quite good with computers the more I go through these problems. I've been building them for years now and it gets easier to diagnose each time.
  • sowen010599
    sowen010599 Posts: 343
    The "smell" of new electronics, as well as the "smell" of electronics when something blows, is the flame retardant in the circuit boards. Tetrabromobisphenol-A, polybrominated biphenyl, and polybrominated diphenyl ethers, are all fire retardants used in printed circuit boards. Tetrabromobisphenol-A is the most common, 95% of all printed circuit boards use it.
    While a component may catch fire, as soon as the board gets hot, and the gases from the flame retardant are released, the fire is quickly smothered. That's why you never hear of a computer, monitor, etc. burning someone's house down.
    Go BIG or go home!
  • nadams
    nadams Posts: 5,877
    Gotta love it when things work out, demi
    Ludicrous gibs!
  • Demiurge
    Indeed. Nothing was fried but my mobo, and I realize I'm very, very luck. *wipes sweat from brow* :D
