intrconnect 3.1tl
2-tall
I have a set of 3.1tl's with what i believe is the wrong interconnnect cable.The one that I have has what appears to be a transformer like box in the line.I have been told that this was used with non common ground amps.I am using a carver TFM 24 which is a common ground amp.Should I be using another cable or is this one giving me the best sound.If not can I make a cable out of rc connectors and 16 gauge wire?
Thanks,
2-tall
Thanks,
2-tall
Post edited by 2-tall on
I would love to trade you a regular interconnect for the one you have.
To answer your question, the one you have will work fine.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Will work fine.
And or. you could build your own.
But if you want to swap, put me in line after Russ.
I'd like to see if it makes a difference on my amp.
-Luc
