psw202 ans psw10
what is the big dif. between the 2. does the 10 use the same amp as the 202. Is it the better amp ?
Post edited by Willow on
PSW202 - last year's model - rear firing port, black only
PSW10 - current model, front firing port, black or cherry
There may be other differences, these are apparent. -
Right I would like to know if the 10 has the good amp or the possible faulty amp of the 202
Willow,
Good luck....I asked this same question (twice) before I bought the 404 and got no response.
Here is the link:
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=23008&highlight=202+ampReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Sounds like a question for Ken. I recently purchased a 202 NIB on eBay for $100, and registered it online here for warranty - no problem. If it ends up having a problem with the amp, my guess is Polk will fix it.
Edit - just followed Mike's thread and I believe Ken answered the crux of the question: the amp isn't "faulty" (as in poor design, etc.), some of them had a component failure.
To quote Ken: "we'll quickly repair and modify your amplifier and get it back to you. The problems relate to the integrated circuit that produces the output power. A small percentage of them develop a flaw, perhaps in the covering material, and require replacing. I believe we also upgrade some of the power supply filter caps. This is not a problem with the design, itself, only a part used in the output section of the amplifier. No matter how much anything is tested there can always be unseen flaws that can cause problems. But, that's what we're here for."
And, from my experience here, I can assure you he's very sincere about that last sentence.
Good luck with your deliberations on the correct sub for you. My 202 fits nicely with the modest HT setup here, and I'm very pleased with the price I paid.
Thanks I am not contemplating between the 2 just wondering ...thanks for the info
