Any luck with this setting?
landry_p2000
landry_p2000 Posts: 1,313
Anybody had any luck with this H/T setting?
Fronts: Large
Center: Large
Surrounds: small
Rears: Small
Sub: 60Hz @12:00
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
Post edited by landry_p2000 on
  • Willow
    Willow Posts: 11,305
    edited November 2004
    I would not set that particular center to large
  • landry_p2000
    Only if I had a CSi5! Dammit!:D Will large not make it louder or make the words more ear friendly? Or would it put too much on that CSi3? Why not? :confused:
  • Willow
    I don't think it is big enouhg to handle the lows. yes if you had the 5 for sure...I wish I had the 5..I have the 3 as well..
    The lows will be better handled by the sub.... my thoughts on this
  • landry_p2000
    Setting it to large will send bass through the center? If this is so then you are correct. The highs and mids would be better with this set on small. I'm still a rookie, but I am learning! :D
    Thanks Willow
  • gregit
    gregit Posts: 284
    For what it's worth, I have the 5 and I found that setting it to small sounds the best.
    RTi10s-large
    CSi5-small
    RCi60-small
    SVS- 60 @ 12:00
    LFE/Bass-Both (LFE to sub, all other bass signals to front and sub)
  • landry_p2000
    edited December 2004
    RTi10s-large
    CSi5-small
    RCi60-small
    SVS- 60 @ 12:00
    I guess the bass from the LARGE setting tends to take away from SQ? I will try it tonight when I watch HERO.:D
    I am set to all large right now. I will set all to small except for the RTi10s during the movie. I hope this gives me the sound that I am looking for. I have tried the setting many different ways. Tweaking and adjusting is just a way of life for us I guess! I will let you know how it turns out.
    Thanks for the help!
  • landry_p2000
    I set all to speakers to small except for the towers. The bass to the sub has increased dramatically. The bass circuit has redirected the bass to the towers and sub only. The center and surrounds are giving me a more detailed high to mid range sound. The way I tested my surround effects was to cut off the sub and listen to the speakers only. This helped alot. Thanks for the input.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Landry,
    Have you calibrated your system with an SPL meter yet?
    RT1
  • landry_p2000
    Not yet. I need to be schooled on how to use that joker.:confused: When I get it I will be bugging the hell out of you guys reel.:D
