15 hrs in the making
Willow
When my wife and I bought our new house it didn't come with fire place matel. It did however have ugly marble surround. Saturday we spent 11 hours building a new mantel and surround. Wow is all I can say what a difference. Trying to post pics but pics are too large......GRRRRRRRRR!!!
This is the latest project in the house....keeps me busy not thinking or being able to afford more audio gear. Also make my wife happy....a happy wife is an agreeing wife (for when I want to buy gear)
If some one would be kind enough to help me post pics I'd like that....just a before shot, a during.....the after will come next week we have sanding , trim and painting to do before I will have a final pic.
JF
JF
Post edited by RyanC_Masimo on
send them to me and I'll host them on my server for you to link to here if you can't get them small enough to fit here...
danny.scarbrough@logixdesigns.com -
Thank you it will have to be later today I send them to you I'm now at work.
Thanks again. -
There's also a bunch of programs out there on the web that will help you shrink photos, assuming you're computer savvy enough to use them. Chances are if you can't upload them to this site your email server won't take them either. If you are using a digital camera, it most likely came with software that will do this for you, but there are also free trials of other programs that do it.
Try this one Batch Image Resizer
Good luck!If you will it, dude, it is no dream. -
Thanks. I have tried with the software that comes with the dig cam....I can shrink them but when I try to attach I can't find my pics anywhere..... I know how to use a puter but I'm no savy....that's why I call my bro all the time.....
MS Paint
Toolbar: Image
Stretch/Skew (I think) - then pink a percent of the original size, and wa la- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks something else to try:)
Sorry I had no time to log on to the puter, Bush was in town and what normally takes 15mins to get too took 45 mins....so I was on the bus for 1hr when it takes 20 mins to get home......Then I worked on the fire place....filling holes and sanding. I will try tonight to get picks.
I got time last night and had problems with my hotmail, I will be sending them your way if you don't mind Ill send you 2 1 before and one after
