PSW202 or PSW10. HELP.
sanzaldi
sanzaldi Posts: 1
HELP!!!!!!!!!!!!!!!!!!!!!
What is the difference between PSW202 and PSW10?
PSW10 is not magnetic shield. Is this bad?
What is the better for me? (I have Monitor 60, Monitor 30 and CS1).
Is PSW202 discontinued? Is this true?
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:confused:
Post edited by sanzaldi on
  • faster100
    faster100 Posts: 6,124
    edited November 2004
    FWIW, these are basically the same sub, it should be shielded regardless of what the description says.. the new sub matches your current speakers.. the psw202 was last years model... either will work pretty good.. the new psw10 or what ever the name is will match in looks and grill style to your monitors... and has a front air port hole..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • PolkThug
    PolkThug Posts: 7,532
    Go for the PSW10, newer design, larger cabinet.
