Wiring Question
bobbyg55
I have just purchased a set of T90e Euros.
What type of wire should I use for basic hookup?
Bobby
Bobby
What's your price range and what kind of gear do you have?
If you're going to use a generic stranded copper, get at least 14awg.
If you're looking for a specialty cable solution....here comes about 600 different opinions! Good luck.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Steve,
Thanks for the information and advice. -
btw, is oxygen free really important? -
I purchased 14awg and the sound has been excellent.
