rti12
Hello,I have a ? about bi-amping my rti 12`s. I am currently useing an ATI2505 with them now,was wondering how many watts the mid`s and tweeter can use(handle) .Thinking in the 150 to 200 range.Thanks for any response.
Post edited by jimi64 on
The MW-Tweeter section will take as much as your ears can stand. While you can get away with less, don't be afraid to give them as much power as you do the sub's.
While the power to the subs' will likely be greater a higher percentage of the time, the MW's and even the tweeters signal will have some pretty stout transients.
Bi-amping with 2 of your ati's channels per side should do quite nicely.More later,
Tour...
Vox Copuli
