Polk PSW 303 vs $99 Dayton 10" sub?
I already have a 303 in my office rig. Would the Dayton sub be a signifigant upgrade for only $99?
Post edited by marker on
Bump.
Nobody has had any experience with both of these subs? -
unfortunatly, i have little to no experience with both. if i had to wager a guess though, i would say the 303 has higher spl levels (shear volume) but the dayton will probably have more quality of sound. i base this on the many raves i have heard about that little sub. this choice will depend on the size of the room. if it is larger, might want to stick with the 303, but if you have a smaller room, trying the little dayton would be worth it.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
of course, another option would be to pocket your money until you can step up to a more significant sub. the HSU stf-2 is a fave in the sub 500 category. closer to 500 is the hsu PB10 that people have also been raving about. if you have some semblance of woodworking skill, DIY is an option if your looking for bang for the buck. i built my own sub and will never go back.Living Room 2 Channel -
