Screen Flicker when solid black on a rear-proj HDTV?
Bonham
Just curious if someone has experienced this.
When my screen is very dark, I get a screen flicker ('white' light) that is mostly noticable on the black bars (if watching a DVD for example). Not sure 100% if it's carrying over to the actual picture... I can't tell if it really is or if it just appears that way.
My immediate reaction is that I might need to replace the bulb.
Just... Bonham
Hitachi 52" Rear Proj' HDTV: 51XWX20B
Comcast Motorola HD/DVR Cable Box; DCT6214/2005
Sony Prog' Scan DVD; NS752P
Harman Kardon AVR 7300 Receiver
Harmony 659 Universal Remote
Polk Monitor 70 Front Mains
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds
Post edited by Bonham on
First off, the 51XWX20B is a 51" unit, not 52". Secondly, it's 238lbs of pure CRT based love. If you can find a bulb in there, you'd be an amazing man.
Manual available here..... http://www.amazon.com/exec/obidos/redirect-to-external-url/ref=mt_mo_view_14453/103-9662372-5983849?path=http%3A//media-server.amazon.com/exec/drm/digital/moleproxy.cgi%3Fname%3DSGl0YWNoaSA1MVhXWDIwQiA1MSAxNjkgUHJvamVjdGlvbiBIRFRWIE1hbnVhbA%3D%3D%26file%3DTUFOVUFMMDAwMDE5OTY2LnBkZg%3D%3D&append-uid=no
Call the Hitachi service hotline, 24/7 @ 1-800-HITACHI or
1-800-448-2244. I'm sure they can point you in the right direction.Go BIG or go home! -
I had the same problem with my Hitachi 51SWX20B, had it serviced twice and the problem was still there. They couldn't figure out what was causing it. Ended up having it replaced with a 50V500, couldn't be happier. Thank god I got the CC warranty, had great service from them. Good luck.My Set-Up:
Sharp LC60E88UN- Display
Yamaha RX-A2020- A/V Receiver
Pioneer Elite BDP-23FD Bluray Player
Toshiba HD-A2 HD-DVD Player
Velodyne DPS-12 - Sub
Polk RTi8's- Fronts
Polk CSi5 - Center Channel
Polk FXi A4's- rear surrounds
Monster HTS2600 Line Conditioner
PS4 -
First off, the 51XWX20B is a 51" unit, not 52". Secondly, it's 238lbs of pure CRT based love. If you can find a bulb in there, you'd be an amazing man.Just... Bonham
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds -
For DLP rear projection, there is a bulb. For CRT rear projection, there is no bulb. There are three CRT's (cathode ray tubes), each making a picture in red, blue, and green. Sometimes these are referred to as guns, or color-guns. Each CRT is very similar to a regular direct view TV except they only make one color each. The three images combine to make one color image. Just like there is no bulb in a regular direct-view TV, there is no bulb in a CRT RPTV.Go BIG or go home!
