LC60i rated at only 4 ohms
10-SE
10-SE Posts: 5
edited November 2004 in Speakers
Brochure mentions nominal impedance of LC60i at 4 ohms. This is a 4 ohm speaker, procluding the use of many amps? If using a Denon 1905 rated at 6ohm min. should TC60i be used instead?
Kris Gentry
Post edited by 10-SE on
  • hotwheelman
    hotwheelman Posts: 1,300
    Welcome to the forum, I would say you would want to stick to the min. ohm rating for the receiver. A four ohm load would more than likely present an issue for the denon, what part of Tn. are you located?
    HWM
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • bertram
    bertram Posts: 53
    But check out denon's faq (item #9) where they explain about using 4-ohm speakers with their receivers.
    Multichannel Music:
    Sony SCD-C2000ES SACD
    Denon 3803 AVR (pre/pro duty)
    Outlaw 755 amp
    Outlaw ICBM
    Polk LSi15/LSiC/LSi9 (front/center/surround)
    SVS PCU
    HT:
    Sony 9100ES DVD
    Outlaw 990 pre/pro
    Outlaw 7100 amp
    Panasonic TH-37PX50U plasma
    Polk RTi8/CSi5/RTi6/FXi5(front/center/surround/back)
    SVS PCU
    VR3 Posts: 29,435
    You can, buy I wouldnt do it....
    You arnt getting what the speaker can do and you risk damaging it and the receiver...
